got mine today...installed with 1.30 drivers, got the wolfsan dac to work for a bit in hi qual mode. sounded really good.
then i went to setup my tv tuner card, which is connected to the sound card via line out (tv tuner side) to line in (soundcard side). in high qual mode, no sound. in normal mode, sound (after swapping the speaker out line to normal port).
upgraded drivers to 4.32 and found out that hi qual mode disables speaker in (well thats what the engrish said anyway
). tried both the line in and mic port, no sound
anyone know if there is a workaround for this? currently using a playtv pro with dscaler. also have the onbaord nf2 soundstorm if i need to. cheers
edit: btw, you can really hear the difference between normal and hi qual mode
