I can't play DSD files Audirvana because of frequent audio dropouts.
It happens both with Topping D90 and RME ADI 2 DACs. I tried DoP 1.0 and 1.1.
Other players (HQPlayer and Colibri) work just fine.
Does anyone know what to do?
Audirvana Mac Version 3.5.41 (3571)
macOS 10.13.6 with 16384MB RAM
SIGNAL PROCESSING:
Polarity Inversion:
Globally: OFF
Per track: ON
Effects plugins NOT ACTIVE
UPSAMPLING:
SoX not in use
SoX filter parameters
Bandwidth at 0dB = 99.5
Filter max length = 30000
Anti-aliasing = 100
Phase = 66
AUDIO VOLUME:
Max allowed volume: 100
Replay Gain: None
SW volume control: OFF
=================== AUDIO DEVICE ========================
CoreAudio audio path, buffer I/O frame size: 512
Max. memory for audio buffers: 15360MB
Local Audio Engine:
Exclusive access: Enabled
Integer mode: Enabled
Preferred device:
ADI-2 DAC (58480958)
Model UID:ADI-2 DAC (58480958):2A39:3FD3
UID:AppleUSBAudioEngine:RME:ADI-2 DAC (58480958):57BAEB6B6D250C8:1,2
Currently playing in Integer Mode:
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
Bridge settings:
Sample rate limitation: none
Sample rate switching latency: none
Limit bitdepth to 24bit: OFF
Mute during sample rate change: OFF
Selected device:
Local audio device
ID 0x46 D90 Manufacturer:Topping
Model UID
90:152A:8750 UID:AppleUSBAudioEngine:Topping
90:14200000:1
10 available sample rates up to 768000Hz
44100
48000
88200
96000
176400
192000
352800
384000
705600
768000
Audio buffer frame size : 212 to 4096 frames
Current I/O buffer frame size : 512
Volume Control
Physical: Yes
Virtual: Yes
MQA capability
Auto-detect MQA devices: No
Not a MQA device, user set to not MQA
DSD capability: DSD via PCM 1.1
Device audio channels
Preferred stereo channels L:1 R:2
Channel bitmap: Ox3, layout:
Channel 0 mapped to 0
Channel 1 mapped to 1
Audio channels in use
Number of channels: 2
Use as stereo device only: No
Simple stereo device: Yes
1 output streams:
Number of active channels: 2, in 1 stream(s)
Channel #0 :Stream 0 channel 0
Channel #1 :Stream 0 channel 1
SIGNAL PROCESSING:
Polarity Inversion:
Globally: OFF
Per track: ON
UPSAMPLING:
SoX not in use
Anti-aliasing = 100
Phase = 66
AUDIO VOLUME:
Replay Gain: None
Local Audio Engine:
Preferred device:
Hog Mode is on
Bridge settings:
Selected device:
Local audio device
Model UID
44100
48000
88200
96000
176400
192000
352800
384000
705600
768000
Volume Control
Physical: Yes
Virtual: Yes
MQA capability
1 output streams:
