joe_cool
- Dec 8, 2002
I hope this works.
http://ndbafw.bay.livefilestore.com/.../IMG_0159a.jpg
Could someone please explain to me what this 'amp-rolling' or something means?
I'm considering this DAC and would like to know what that is.
Thanks in advance and sorry for the noobish question.
Opamp rolling means to replace the operational amplifiers inside the unit to change or flavor the sound in different ways. Rolling usually suggests that you replace, test, and replace again, looking for a combo that fits your tastes.
Ah, I see. Thanks for your reply.
How much of a nessesity is Opamp rolling do you think? Because I'm considering both the Dr. DAC2 DX and the Matrix Mini-i and I know the mini-i doesnt have this Opamp rolling option right?
Do you think that I will miss this function would I decide to go with the Matrix Mini-i ?
Cheers.
Thanks for the help all.
I'm seriously considering the DAC2 DX right now, but there is still one thing about Opamp Rolling before I make the purchase...
How do you do it exaclty? I know what it means and what it does, but how do you do this rolling of Opamps within the device? Do you do it by changing some things on the chip board? Or do I have to buy anything for it?
Sorry once again for this noobish question, but I'm fairly new to this so I just want to learn. I hope any1 can help me with this.
Thanks in advance.
You just replace the stock opamps with higher quality units or units that are a better match for your taste. Many audio devices these days come with opamp sockets which allow you to easily snap in new opamps. Check if the unit has sockets, I think it does but I don't own that so I cannot be sure.
On the PCB board itself. I would suggest that is you are unfamiliair that you do some reading..etc to prevent you from damaging the units, opamps or both.
