Wodgy
- Feb 24, 2002
So you don't trust online reviews of solid state amps but you trust online reviews of digital amps? Seems odd. It's better to be wary. There is a lot of fishy stuff out there, and you should really listen for yourself before buying or recommending to others.
For instance, there are reviews online claiming that $50 digital amps you can buy at Target destroy mythical $1000+ setups. How likely is this to be true, given that the unit itself likely contains about $5 worth of parts, including the power supply? No one ever posts measurements.
From what I've seen, a lot of the online reviews of digital amps compare them not against their solid state brethren but against low-power, single-ended tube amps, such as EL84 designs. The thing is, in my experience they do have a lot in common. 8-watt single ended tube amps usually have nice highs but very little bass control, sounding slow and bloated. (Whether this is caused by a lack of power or a low damping factor I can't really say.) In my experience, digital amps sound a lot like that. They have smooth highs, and somewhat deep bass, but the bass is often soupy and uncontrolled. It's not surprising, since they tend to be underpowered and have a low damping factor. You can almost never find accurate measurements of digital amps, and many of the power claims are simply misleading. 100 watts peak? That means what in the real world? 20 watts continuous? Less? At what level of distortion?
The two amps I have are a Sharp SD-SH111 and a Sharp SD-SX10 (not sure about the model number of the last one). For the price I paid for the SD-SH111 ($150), it was a bargain since it plays DVDs and doesn't sound too bad, but there is no comparison between it and my current inexpensive favorite conventional amp, the Pioneer Elite A-35R (around $150), driving speakers. For instance, in my review of the SH111 I mentioned that I needed to use it with a self-powered subwoofer because the amp's control of low bass in my main speakers was poor. I agree with you that some of the low end solid state competitors sound terrible -- you've probably seen me relentlessly pan the NAD C320BEE which is clearly not worth the money in my opinion, but that doesn't mean they all sound bad. Shop around and audition. You may find that you prefer the digital amps, but in my experience the digital amps are no low-cost magic bullet. You tend to get what you pay for.
