mullardpassion
- Nov 12, 2013
I have listened to Mini+ not Yamaha HS monitors.
If my budget was under USD 1000, I'd go with the Mini+ any time. Blindly.
Mini+ costs around AUD/USD 800-900 or so. And it is well worth even more.
I would rather stick to home speakers for home use. Don't want to risk a harsh studio monitor when I can't even audition or return.![]()
And AE isn't audiophile grade. It isn't even close to the
AE will lose out to $100-150 passive speakers with a $100-150 speaker amp. Badly.
Aktimates would likely thrash them. Mini+ that is.
Hopefully someone won't listen to you blindly. Also what is 'audiophile grade' to you??
Anyways, I don't think you can go wrong with AudioEngine speakers. Don't focus on what is 'audiophile' or not. Also you don't get better speakers, the more you spend.
Just try to get a listen before you buy..and why not the yamahas too. I found the smaller yamahas monitors to be bright, maybe the 7 or 8 speakers will suit you. Keep in mind your listening setup: nearfield,etc.
I also think its a good idea if you're buying locally as you stated shipping cost is high and you can get assistance whenever you have a problem.
