Audio Technicia Ath M50S LE VS Skullcandy FIX In-Ear Buds
Nov 11, 2012 at 1:49 PM Thread Starter Post #1 of 4
lakersfan2424
Right now, I have the Skullcandy FIX In-Ear Buds, which I listen to with my iPhone 5.
I usually listen to pop, rap, or alternative music and I was wondering if I should
stick with my earbuds or buy the Ath M50S LE. I want headphones with good SQ,
a good soundstage, good noose isolation, little sound leakage, comfortable,
sliglty bass heavy, can be driven well an iPhone 5, don't require an amp, and are preferrably over-ear. Being relatively light would also be an aspect I would prefer to have in my headphones, but it is not nevessary. Also, I want headphones that are mond of portable. Would buying the Ath M50S LE be worth it or should I stick with my Skullcandy FIX In-Ear Buds?
Thanks for any help, it is all apreciated!
Jan 24, 2013 at 3:43 PM Post #3 of 4
I've never heard the SkullCandies, but I doubt any earbuds in that price range would even be close to comparable with the ATH-M50s. The ATH-M50s seem to be a very solid option for you, although they aren't particularly light/portable and the soundstage is a bit lacking compared other fulled sized cans. Without even trying out the SkullCandies, I'd be willing to wager that the diference with the ATH-M50s will be like night and day. Highly recommended.
