Audio-Technica ATH-R70xa
Jun 1, 2025 at 6:27 PM Post #91 of 93
What is the fit stability on these? I've read that they have low clamp force and the headband kind of flops around - so I'm concerned that they'll slide off the head relatively easily like the HD800s tend to do...?
Are they stable on the head, or do they slide out of position easily when you look up or down? (Please state if you have a large or small head for reference...)
I had a little time with it at a CanJam. Very feather light and comfortable to me with a medium-ish size head.
Since it is a metal and flexible headband you could likely bend it inward or out to get a better fit.
Jun 2, 2025 at 12:48 AM Post #92 of 93
Can't quite remember the brand, I did bought it a few years ago, didn't get the idea til last year when I became really frustrated with the lack of bass on the AD-700X. This kind of weather stripping though. I also included a picture of what it looks like on the inside of the headphone pad. Helped with the seal for me tremendously. Hope this helps!17439727078775213364332537741652.jpg
this is a great idea thank you i can apply to other headphones.
Jun 3, 2025 at 3:33 AM Post #93 of 93
I ordered the refine pads from Apos, curious to try those.
To the person asking about fit, I have a medium to large head and they don’t move around too much. I’m thinking firmer pads would help that even more. The stock pads are comfortable but I prefer a firmer pad
