Stereodude
- May 23, 2006
AAC-LC compression is better than you think it is. You can cut those bitrates in half, using the right encoder and settings, and not hear the effects. In my ABX testing AAC goes transparent at less than ~128kbit/sec using true vbr & highest quality with the latest Quicktime encoder (outside of Quicktime). You should try it and see.
I don't care about lossy compression filed on my iPhone at all. Almost all of my IEM's (Grado GR10 - e-Q5) aren't revealing enough to show the effects of a lossy compression of 256-320 Kbps AAC file.
