Dobrescu George
Reviewer: AudiophileHeaven
From their official website:
APR 204
The launching of the vacuum tube stereo power amp Qualiton APX 200 entailed the demand for developing a thoroughly classic vacuum tube preamp. The vacuum tube preamp Qualiton APR 204 is meant to meet this demand by not wanting to seem to be more than it is: it is in fact one indispensable element of the sound chain which was developed based on clear guiding principles and is able to evoke the classics of tube electronics.
At the same time, three audio sources with line level output signals as well as one signal source with MM phono output signal level can be connected to the RCA connectors at the rear panel. With the help of the audio source selector switch at the front panel, the user can determine, out of these four audio sources, which one of the relay-switched, volume-controlled signal should reach the output RCA connectors.
If the input selector unit is in ‘P’, i.e. PHONO position, the signal to be processed gets on the grid of the first voltage-amplifying vacuum tube through RCA connectors marked PHONO - thus, through the shortest possible signal paths. From here, in the before-mentioned classic way, the signal component gets on the grid of the second voltage-amplifying stage through a passive correction network between stages according to RIAA standard, realised exclusively with passive elements. We use both in the first and in the second voltage-amplifying stage double triodes ECC83/12AX7. Through an appropriate tuning circuit and volume control potentiometer, the output of the PHONO stage is connected to LINE stage, consisting of double triodes E88CC/6922.
Warranty: 2 years (6 month for tubes)
User's manual
Some photos too:
Currently waiting for reviews and more articles about it coming online too
I am not affiliated, just made a thread about it btw. I will review it in the near future, but that is all the connection I have with the company.
APR 204
User's manual
- TECHNICAL PARAMETERS
Name Value Nominal output level - Line 2 V Input sensitivity - Line 500 mV, to nominal output level Input sensitivity - Phono 5 mV, to nominal output level Number of input ports 3 unbalanced input per channel, 1 MM-level input per channel Number of output ports 1 balanced/unbalanced line level output per channel, 1 headphone output per channel Max. input signal - Line 7 V Max. input signal - Phono 200 mV Gain - Line +12 dB Gain - Phono +52 dB, (f = 1 kHz) Total harmonic distortion - Line < 0.05%, (f = 1 kHz, input level: 500 mV) Total harmonic distortion - Phono < 0.5%, (f = 1 kHz, input level: 5 mV) Frequency response - Line 4 Hz - 300 kHz, (-1 dB) Frequency response - Phono 20 Hz - 20 kHz, (-0.3 dB) Input impedance - Line 100 kOhm Input impedance - Phono 47 kOhm Signal-to-noise ratio - Line > 100 dB Signal-to-noise ratio - Phono > 70 dB Tubes required 4 x ECC83/12AX7; 2 x E88CC/6922 Weight 8.4 kg Dimensions 43 x 10 x 32 cm
Some photos too:
