- May 26, 2009
all listening now is fully balanced using the hd800 and the OPPO BDP95. It is fully burned in and has not changed much from the first day.
yes. fatiguing
I dont know other cans it would be a perfect match for and with. The amp is not bad but its no giant killer or close to being one. It not very dynamic and I am using two reference headphones and a few mid tier headphones,. I notice hardly any differences and as far as listening I am putting hours on them and nothing going to change the opinion on them. They are not a giant killer nor will the be IMO. maybe to others they will reside in a lower priced system will be happy with these. I will do a complete write up in a couple of weeks when i do have more hours and I also want to try some other balance interconnects to see if it helps. I also think you would be at a disadvantage to deprive your HE500 and HD800 of the dynamics thats makes them so special. I also would not buy balanced cables for my AKG550.D7K or Beyer 770
Hey Frank!
Any insights on a NFB6 (via balanced) vs the Lyr for the He500?
Cheers!
Hi Frank, Do you think the NFB6 would be a good match for the HD650 in balanced mode?
I am curious as to how much better the hd650 will sound running in balanced mode. I am running it through the V100 atm and wonder if this will give me a better performance in balanced mode - I have a TWag V2 balanced cable with a pigtail so I can go balanced or SE
