Audio-Gd Master 7 - Discrete Fully Balanced DAC (PCM1704)
Feb 23, 2025 at 4:29 PM Post #4,471 of 4,475
I have the latest firmware installed and for the sake of science, humanity and my peace of mind I tested my M7 with PLLEN jumper off and on. I had it ON currently and it didn't sound as bad as I thought it would with the jumper OFF. Most definitely needs to be ON to bypass the internal clock.
Feb 23, 2025 at 5:44 PM Post #4,472 of 4,475
PLL off (jumper on) is the best to me too.
Feb 23, 2025 at 6:35 PM Post #4,473 of 4,475
Interesting mystery.
This page states the setting you refer to, and states support up to 192kHz.
But this page, which states 2016, DSP version 7, and 384kHz support via I2S and USB, shows the opposite settings. My M7 did play back 384kHz after installing the firmware, so I assume that the settings on the 2016 page were the correct ones.
Feb 24, 2025 at 12:54 AM Post #4,474 of 4,475
It does sound like there may be different settings depending on the M7 version. Better people know about it and can try both if in doubt. Even before I got the external clock, bypassing PLL using i2s from a DI20 made a significant positive difference. Nice how flexible this dac was designed to be.
Feb 24, 2025 at 4:01 AM Post #4,475 of 4,475
What a mess with these AudioGD products,
until today I have always read that to go into "NOS" mode the jumper MUST NOT be positioned on "Bypass".....
My Master 7 is from the end of 2016 and has the updated firmware V7
The Master 7 prior to the Singularity version has no internal clock and uses the source clock, so the very kind Jos from Magna Hifi tells me.
