DACLadder
- Feb 16, 2013
So DACLadder, just to confirm - the 1 kHz square waves we're seeing, they're good/acceptable even with the ripple we're seeing?
In the editor I see the same ripple in the 1kHz downloaded file as I observe on the output of the M7 when the file is played back(below). So the M7 seems to faithfully reproduce what you input. The mild ripple is due to the limited bandwidth at 48kHz sampling rate when the file is created. Tomorrow morning I will generate some test signals and put them on SkyDrive for you to use.
