If you STOP the playback, windows will be able to play sounds. If you PAUSE it, jRiver will keep exclusive control over the playing device.
Audio-Gd Master 7 - Discrete Fully Balanced DAC (PCM1704)
- Thread starter DarknightDK
Steph86
Member of the Trade: BusiSoft AV / Addicted to Audio
- Sep 26, 2007
mmm, I think this is the same for Foobar also.
Clemmaster do you also use ASIO for output?
No I use WASAPI.
JRiver had (and probably still has) an option to disable the exclusive access on the device, which allows to have the windows sounds at the same time (at the expense of sound quality, probably).
ciphercomplete
- Feb 21, 2008
I downloaded the new driver yesterday but I haven't got around to trying the various modes yet. The improvement isn't as drastic as the last driver update which was amazing but I did notice a little better focus. The BS Deck has been out since the last update and its absence is probably the reason behind the improvements.
ALRAINBOW
- Oct 5, 2012
Nothing I have tried ever has made the M7 bass as tight as it needs to be. It really nice tones and good clarity it's only issue to my ears is the bass is a bit over the top but also not as detailed as it needs to be. . I have tried the offramp and the ap1/pp. The new driver /firmware helps this but does not resolve it all together. .
Al
Al
ciphercomplete
- Feb 21, 2008
Al
Yeah, and I think that is a weakness of the dac chip itself. I have owned a couple 1704UK dacs (non audio gd varieties) and while they were no where as good as the M7, the bass had that same sort of looser characteristic. Its definitely the M7's Achilles heel.
ALRAINBOW
- Oct 5, 2012
As I am glad you agree we will both be bashed shortly hahaha. It's shame it's a great dac for headphones . There is a dac called the trinity big bucks and it uses the same 1704 chips. I have tried anything I could think of to solve it.
Honestly I think the problem may be in the PSU for the dac itself. I are done all there is to it . Rj45 with an offramp , the HDMI with an offramp. A i7 CPU with SS drives win 7 PPA USB PCI x and linear PSU and the PPA red USB cable. Of I knew how to add on a better PSU I would try it. .
Al
Al
ciphercomplete
- Feb 21, 2008
Al
I hope not, its an honest assessment. Overall this is still the best dac I have personally owned just not the best in the bass category. Fortunately I have diy speakers that use servo subs to handle everything below 200hz and I can adjust the dampness on the sub amps to make the bass tighter allowing for at least some of that obscured detail to be heard.
krumme
- Oct 18, 2010
I understand what you both hear and yes i also think it can be attributed to the 170x, but you interprete it wrong imho. The roundness vs dryness is more correct vs real live non amplified sources imho. I think its a general ladder vs streaming technology characteristics. 1 bit dacs never have the needed roundness to the tone imo, but they have other qualities like perhaps a musicality-sweetness to the midtone.
mowglycdb
- Nov 29, 2011
I feel the bass is fine and tight but I haven't heared other sources on the same level. The tone of the Master-7 is one of it's strengths at least putin thinks that way. I enjoy it a lot for some genres but for others it's not that great, soundstage is too big and looses intimacy.
ciphercomplete
- Feb 21, 2008
That may be the case, it probably is just a personal preference thing. I am nitpicking in complaining about the M7s bass. Its just to my ears the bass performance doesn't quite match how great the dac performs in the other frequency ranges. FWIW I am certainly not rushing out trying to buy another dac.
mowglycdb
- Nov 29, 2011
the PPA card fixed my BSOD problems WOOOO!!
ALRAINBOW
- Oct 5, 2012
Good I am happy for you .
Al
Al
decapitate85
- Mar 31, 2014
What is your buffer setting from Asio control panel with the new driver?
I tried with 5, but with DSD files after 5 or 6 songs it began to slow down and stutter (in Jriver I put 25 milliseconds).
drez
- Sep 7, 2009
I turn windows souns off. Who needs them?
Total: 6 (members: 0, guests: 6)
