FauDrei
- Mar 6, 2007
...and I thought this was Master-7 thread...
It is, I had problems of my system rebooting with master-7 (using facebook or youtube and some other stuff) so the or5 would correct it
What player do you use?
I had the rebooting problems some time ago and found two possible causes:
1. USB connection/cable:
- Try different USB port of your computer.
- Disconnect and reconnect the USB cable on both sides. /This helped me to some extent.
- Try a different USB cable.
2. Software problem: A conflicting combination of your audio player x drivers x system x system component x soft-related-etc.
My case: I loved foobar with Kernel Streaming and Wasapi but I had occasional rebooting problems with the built-in USB input of my M7 and with the Offramp (I2S) as well. I bought JRiver (use it with Wasapi) and no rebooting issues anymore. Everything is flawless now.
Anybody heard about the Gustard U10 converter? It is an affordable Chinese X-MOS converter that features i2s over HDMI and a built-in LPSU.
Could be fun to try for those with DACLadder's HDMI board.
Dac ladder.
Have you tried the PPA USB PC E card
I am building a win 2012 system but piped it in my win 7 CPU
Wow what an inprovemt overall.
Just the card 130 and a linear psu I had from audio GD
And a reg they sell at PPA. and it's really very good
Al
http://ppaproduct.blogspot.tw/2014/01/linear-dc-adapter-for-battery-supply.html
http://ppaproduct.blogspot.tw/2013/07/audio-grade-usb-30-pcie-card.html
The above links are the battery trey and the PCI express usb card
Al
