junkers
- Jan 25, 2011
Any more reviews of this unit? It's been a couple months so I'm assuming the units are well broken in?
I should be writing a review soon (week or two). Going to compare this to an objective 2/odac (ODA)and a graham slee bitzie.
I think that with a non-crappy power supply (£10 worth at least) and a suitable power conditioner (as for all audio equipment) the Audinst sounds quite a lot better running on AC. Without AC the ODA handily beats it across the board. But when plugged in they both sound very similar and it's anyones choice which they prefer.
A couple of questions:
- any idea what I should set volume for to achieve 2V ptp line out level?
- I assume feeding this 12V when using only as a DAC will not provide any benefit?
Thanks,
G
Hi, I've gotten the mx2 for a while now, realized its been shutting off every so often.
Question is, must I connect the power as well? It can't run off usb power?
