JDUBS
- Jan 3, 2003
Guys
Question for you Audigy 2 NX users. I'm using Foobar with the SRC upsampler (24-bit fixed point, 96khz). I want the Audigy to output this.
I the Audigy "Device Control"...I have the "PCI / USB" tab set to 96 khz and 24 bits. I have the "SPDIF" tab set for 96 khz under the "SPDIF Output Sampling Rate". I have the "Decoder" tab set for "SPDIF Passthrough".
I just worry that the Audigy is reampling the 96 khz signal it is getting from Foobar.....and I would like to avoid this if possible.
Does anyone have any ideas?
Thanks!!!!
-Jim
Thanks!!!!
-Jim
