Dixter
- Dec 21, 2011
for those in the know... just how much different is the sound between the LCD-3 vs LCD-4 .... thanks
anyone know where there might be some new stock left over for the LCD-4 that I could purchase... if so please feel free to send me a PM reply..
thanks
USA... thanksWhich country?
I do use EQ, but... I recently swapped to the latest open cell pads which helped with the upper mids dip quite a bit. This also had the unfortunate consequence of me messing with my eq settings more than actually listening and enjoying the music. Been struggling to find a sweetspot of what sounds best honestly. Between that and equalizer APO constantly breaking after windows updates, I've turned off EQ for the past week and it sounds great on most tracks tbh.Btw, forgot to ask, do you EQ?
You mean Audeze's current replacement pads? I wonder what I have...were they originally memory foam?I do use EQ, but... I recently swapped to the latest open cell pads which helped with the upper mids dip quite a bit.
I feel like the mids become a little too forward with the open cell pads IMO. This is because of the felt pieces they provide with the pads.What software is that through? If your LCD4's were made before November of 2020 then its using the original memory foam pads. The new pads are open cell and are squishier/softer. It seals better but your ears are closer to the driver. I like the comfort of the new pads more and you don't have to eq the upper mids dip as much.
I think the felt pieces have a different purpose. Anyway, I enjoy the tuning with the new pads more.. I don't find them too forward. Here's the frequency response courtesy of Audeze.I feel like the mids become a little too forward with the open cell pads IMO. This is because of the felt pieces they provide with the pads.
The felt pieces reduce resonances between the pads and raised section of the drivers. Also, the drivers are much closer to your ear. I think this does make the mids become a bit forward which helps with the mid dip from older pads. This is why EQ is my friend.I think the felt pieces have a different purpose. Anyway, I enjoy the tuning with the new pads more.. I don't find them too forward. Here's the frequency response courtesy of Audeze.
FabFilter Pro-Q 3, through SoundSourceWhat software is that through?
Quite a big upgrade in terms of stereo imaging, detail, bass, dynamics, vocals and timbre of instruments.for those in the know... just how much different is the sound between the LCD-3 vs LCD-4 .... thanks
thanks for the reply.... now to find a new pair...Quite a big upgrade in terms of stereo imaging, detail, bass, dynamics, vocals and timbre of instruments.
Don't quote me on it but if you absolutely want "new" I think you can contact Audeze to build you a 4 but with LCD4z parts. The driver will be tuned like an LCD4.. Otherwise just gonna have to keep an eye on the used market for a mint pairthanks for the reply.... now to find a new pair...
They won't do that anymore.Don't quote me on it but if you absolutely want "new" I think you can contact Audeze to build you a 4 but with LCD4z parts. The driver will be tuned like an LCD4.. Otherwise just gonna have to keep an eye on the used market for a mint pair
