Blasto_Brandino
Has changed names to BattleBrat
- Apr 10, 2010
Alright, I have two turntables, neither of them have a tonearm installed.
I am willing to purchase ONE tonearm ( that tonearm is the Trans-Fi T3 Pro, Do not try and convince me to buy another arm, that is the one!) For ONE Table
The other table will be sold and the funds will go toward a speaker upgrade.
Price paid;
~$400 out of pocket, I paid the rest off through work on a out of work realtor's car (I'm a mechanic, keep in mind I'm only 24yrs old)
Condition;
EXCELLENT! Has less than 1,000 hours use, the friggen table is new! It is simply incredible! NO holes drilled in plinth (my most MAJOR of pet peeves regarding Turntables)
Pros;
All I have to pay for is the servicing, installation of the Linear Arm and the cartridge.
It is a HIGHLY rated table I was VERY fortunate to acquire.
It is in INCREDIBLE SHAPE which means no restoration needed.
It is a MACHINE and would be VERY difficult to purchase an equivalent table
Will match the speakers I plan on upgrading to (Talon Khorus X II's Black and Chrome)
Cons;
To upgrade it FULLY from VPI (Platter, rimdrive, suspension, SDS) is ~$4,000, but I don't HAVE to upgrade anything, I can just use it as is.
It is HUGE, and transporting it is a pain (this is my biggest problem with the table)
Parts are more expensive, though readily available.
I feel indebted to the table to purchase a Higher end phono amp for it if I kept it.
Price paid;
$900 in payments off of Audiogon.
Condition;
Fair, needs light cosmetic and mechanical restoration, Hole was drilled in plinth for tonearm holder (WHY GOD WHY!?!) Stylus brush missing, availability unknown!
Pro's;
The table has history, it's 40 years old (thought the VPI is 20)
It is CLASSIC, and looks simply stunning, a far cry from the Semi minimalist VPI.
It is smaller and FAR easier to transport.
Parts are available and (somewhat) affordable.
There is nothing to upgrade.
Con's;
It needs work, I'm guessing 300-400 for the cosmetic restoration, 400 to restore the platter (those weights are supposed to be gold plated, I'll buy new ones) AT LEAST $700 for the mechanical restoration and the parts it will need. and it will STILL have that DAMN hole in the plinth!!! THEN what ever it costs to install the arm
It is not perfect, even restored, it will not be in as stellar condition as the VPI is, lets face it, the VPI is new
Transcriptors is not a major company like VPI 10 years from now, will they be there when I need parts?
The table is simply not built as well as the VPI. The transcriptors is 3mm of Acrylic on a sheet of plywood with a metal surround. The silver you see on the armboard, and near the strobe, is a thin sheet of anodized aluminum on acrylic. The VPI is two slabs of Acrylic, quite simple, quite strong.
The transcriptors will not cosmetically match the new speakers I plan on buying (Talon Khorus X II's Black and Chrome) as the VPI will.
Whatever table I plan on keeping, It will most likely be my last Turntable, EVER, unless I strike it rich and pick up that Rockport Technologies Sirius I that I've been dreaming about.
What table should I keep and throw the arm on? I Cannot Keep Both, There are no real space or noise concerns, I have all the room and can make all the noise I want, Money is no real concern (relatively, I need to upgrade speakers, so one table must go.) I have very low overhead (no girlfriend
) it comes down to what I should keep and what I shouldn't
Please keep your posts on topic
THANK YOU!
Brandon
NOW
TABLE 1
VPI TNT MK1
Price paid;
Condition;
Pros;
Cons;
TABLE 2
Transcriptors Hydraulic Reference Turntable
Price paid;
Condition;
Pro's;
Con's;
THANK YOU!
Brandon
