mplee79
- Mar 13, 2006
I recently purchased a Fatman I-red itube: Link: Fatman iTube Red-i with Speakers
This amp does not provide a headphone jack and only really has speaker outputs. Is there anyway to rewire my Sennheiser HD580 so that I can power them with this amp? Specifically, i was wondering if there was an adapter to connect my headphones to the speaker output?
Is this even advisable given the specs of the amp?
* Power Output: 25Wx2
* Frequency Response: 20Hz - 20KHz (±1.5Db)
* Harmonic Distortion: ≤0.5%
* Signal-To-Noise Ratio: ≥86Db
* Input Impedance: 100KΩ
* Output Impedance: 4Ω, 8Ω
* Valve Type: 2x6N1(ECC85)
* 1x6E2(EM87)
* Power Supply: AC100~120V/50~60Hz, AC220~240V/50~60Hz
* Dimensions: Amp: 450x220x210 mm ( WxHxD), Speaker: 330x315x210 mm ( WxHxD)
* Weight: Amp: 5.8kgs, Speaker: 6.8kgs
I am a total noobie to DIY projects so any part numbers would be greatly appreciated. I don't know where to get the cables to actually connect my headphone male out 2.5mm to the speaker out.
Thanks
* 1x6E2(EM87)
Thanks
