allm1ghty
- Jun 11, 2006
hi,
i got while ago these headphones, but the problem is clattering bass?
for example if i change speaker setup to Headphones or 2.1 channel, then bass is veeery weak and it is clattering. when i change it to 5.1, then bass blows your mind away without any clattering, but it isn't the right setting for stereo headphones, right?
i don't understand. i have Audigy 4 Pro using YouP-PAX modified X-Fi drivers and all.
why is bass weak with Headphones seting and clattering?
also, in Play Control, which one should be in higher level: Play Control (Master sound) or Wave?
thanks in advice..
oh, forgot to tell you that if i roll the Treble bar higher than 50%, then whole sound is whispering (but the clearity isn't enough @ 50%), which did not happen with so called crap Medusa 5.1's![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![frown.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/frown.gif)
thanks in advice..
