Asymmetrical cable design suggestion for BTR3 / M5 owners
Nov 10, 2019 at 8:00 AM Thread Starter Post #1 of 2
cr0ft
Europe
I bought the LC3.5BS short-short cable and use it with my BTR3 and it works very well, and is well made.
However, that's not the best design for a short cable like this. The cable needs to be asymmetrical. For example, the left cable from the cable splitter should be quite short, just long enough to reach the left ear, but the right ear cable needs to be quite long, so it can go around the neck and hang on the right side of the neck when not in use.
The 3.5BS is the same length on both sides, and there is no way you can loop it over your neck. That means you need to use a cable clip to secure it and it still gets in the way if it's not in your ears.
So I need an "LC3.5BSA" - for Asymmetrical...
