You mean use the adapter to try the 2.5mm socket?Get an adapter I recall very old iPhone has a similar issues
But I never experienced this problem though
Astell&Kern XB10 Extreme Bluetooth Adapter
- Thread starter gr8soundz
mthaynes
- May 10, 2015
Hi all just a quick question. I recently got an open box xb10 and the 3.5mm jack keeps popping out slightly when I turn the device, and it cuts the audio out completely. Is this a common issue? And are there ways that I can fix it. Also does it apply to the 2.5mm jack? I dont have a 2.5mm cable to test it out yet. Thanks
I dont have this issue with mine
I tried several 3.5mm cables and all of them popped out a bit after little twist. It cuts out the signal completely when it's in my pocket hope the 2.5mm will not share the same problemI dont have this issue with mine
mthaynes
- May 10, 2015
you may want to send it in for service. should not have this issue. even if you do get one to seat correctly the contact does not sound like it is very good and could compromise sound
The thing is... I bought it from ebay openbox for half the price. I don't think I'm backed by anyone :/you may want to send it in for service. should not have this issue. even if you do get one to seat correctly the contact does not sound like it is very good and could compromise sound
mthaynes
- May 10, 2015
you may be able to return under the ebay guarantee. chances are the headphone jack is recessed to far into the unit. that I probably why it was an open boxThe thing is... I bought it from ebay openbox for half the price. I don't think I'm backed by anyone :/
Indeez
Hi,
Is it possible to mute built-in mic on XB10? While sitting on meetings I quite oftenly switch between mute and unmute. It would be perfect to have such option on XB10, while my phone is in pocket/bag.
