Are you guys getting crackeling noises whe you use your s25's as DAC on laptop/pc's?
Could it be that I'm using a cheap usb-c to usb-c cable to plug into my laptop?
No such issues. I'm using the cable it came with and have the driver installed.
No DAC driver needed for Mac. You should be able to use the default drivers in Windows also for USB DAC mode, but we do provide Windows drivers in case your Windows-based PC does not recognize the player or the driver becomes corrupt and needs to be reinstalled.I’m using Mac. Do I have to install the driver? I tired but didn’t work for DAC. Please advise.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
Am currently using IE80s, wired to a balanced cable, with SR25. One word for this pairing..LOVELY.I have a plan to refrash my DAP usage. I'm about to buy the new Astell and Kern SR 25. I'm using now the Sony NWA-105, with the fantastic Sennheiser IE 800 S in-ears. What do you think guys, will I have have get some significant development in any segments (for first in sound quality)?
Hi Shen I use Bluetooth I only see MAC address of devices in Bluetooth. I live in a apartment where I find 10 MAC address and I don’t know which one is my sound bar. Any way to sort this problem?
Driver is actually stored in the folder on the SR25. It can be accessed directly from Windows Explorer there.
You can also download it here: https://www.astellnkern.com/eng/con...w.asp?search=&word=&idx=1000156&page=1&no=112
Sorry, not sure about Mac. But works great with Windows 10 in DAC mode.
Installed the drivers on my laptop, but still getting intermittent crackling when playing as a DAC.....
Anyone else experiencing this?
I tried with AK connect and it works fine.Does anyone know how to use an iphone as the transport using the USBC input on the SR25? I've tried the camera cable and it wont work - even though it has worked on several other dacs ive used.
