New KC owner here, looking for info that I can't get from the User manual quick enough:
1. I'm a Mac user. Do I have to download any drivers before my macbook pro can see and successfully work with the KC? (I have already downloaded the Android file Transfer application onto my Mac, but I understand that is for transferring files, which I shall do straight away, if I get the issue regarding a needed (or not needed) Mac OS driver sorted.
2. How does one access the open App service that allows the download of other Apps such as Qobuz. Does the open app itself requires some external apps to be downloaded onto my Mac before it can work? I only see Tidal and Deezer Apps preloaded onto the KC, and I would like to get at least Qobuz in addition.
3. I want to transfer music files from my NAS to the KC, preferably onto the Microsd card, as I do not want the KC's onboard native storage space to be clogged too quickly, if I can help it. So what is the best practice for loading music files onto the KC.
Is it advisable to format and transfer the music onto the card on a MAC, before inserting the sd card into the KC, or is it better to format and install the Microsd card into the KC first, and then to transfer the files through drag and drop, with the KC connected to my MAC? If I use the direct drag and drop method, will the KC allow me to determine whether the music goes into the onboard native storage or unto the inserted MicroSd card? I just want the best way to transfer my music into the KC without squandering the onboard storage space, if I can help it.
4. Any other configuration tips not yet referred to that might be useful for new users like me would be very welcome.
Thanks
