Reactcore
Hi AK100 mk1 and AK120 mk1 owners,
Did anyone tried this?:
I have an AK120, and tried to use it as a dac on a samsung smartphone but i cant get it to work.
I bought a 15cm usb cable with on one side a microB and the other side microB otg (=pin 4 and 5 linked)
When i connect the 2 devices, the ak gives the usb screen so 1st i tried to connect to removable disk, this works, i can access the ak's memory and browse files. So the otg function is ok and the cable does transfer data. But now i choose connect to usb dac, then the AK hangs! I have to hold the power button to reboot it.
On a pc the dac functions perfectly.
Specs: the AK runs firmware 1.40
The smartphone is a Samsung S3 running android 4.3 jellybean.
I also tried on a Samsung S5 running latest android 5.0 lollypop but it happends the same.
Both phones dont seem to detect aything when i choose usb dac on the AK
If i look on the Astell&Kern site there is also a AK10 which they claim to work with android smartphones, they even mention the Samsung S3:confused_face(1):
I even thought to downgrade the firmware but irive plus4 wont do it.
Pls help cause the AK site sucks for getting support and would like alot to use youtube or tunein radio on a smartphone with perfect sound:rolleyes:
Thx in advance!
Thx in advance!
