It Hz
I'm in the process of gathering the components for my DAC driven headphone set-up for my computer rig. First, I want to state I am not an audiophile. I'm a guy who loves listening to music who wants great sound from my computer rig for gaming and other computer activities as well. I posted earlier today introducing myself and what is going into my computer rig which has pretty much "top-of-the-line" components. On the Audo side, it's easy to go overboard with spending way more than the computer itself so my budget is hovering around $2000 USD which is where I'm at just about now. I've done my homework and selected the major components even before I joined Head-Fi forums. From reading post here and getting reviews I think I've selected "decent" components but it's often the little things that matter that often get overlooked so I thought I would start a thread to get advice from people who have a lot more experience and knowledge on this than I do.
Here is the rundown of the components I have and planning on ordering:
DAC: Burson Playmate 2 The reason for this choice is the price is reasonable, it has gotten very good reviews for its price range and it will fit in my computer chassis
Headphone: HiFiman Arya V3's Back in my stereo days the one rule I was always told was to spend the money on speakers with these eating up over 1/2 my budget. I have no problem with open headphone as the noise will not bother anyone where I plan to use them. My understand is the Arya's are an excellent choice for headphones for the money
Op Amps: Sparko SS2590's I've read nothing but praise about Sparko products and my understanding is the Burson Playmate 2 reacts very well to them. Michael Bruce's You Tube video on updating the Playmate 2 with Sparko Op Amps was a big influence for me which was backed-up in the comment section, so the single 2590's are going into both LP sockets on the board. As far as changing the dual Op Amps for the IV sockets I'm not sure about those. My understanding is swapping out the stock IC's does not off as much bang-for-the-buck but one commentor stated that a pair of dual SS2590 there will take it to the next level. The problem is the lack of real estate fitting (4) Pro Series Sparkos in the PM2 as I don't want to hack-up the chassis to get them to fit. Another option is installing a set of Sparko SS3602's which I think will fit under the 2590 but I'm going to hold off on that for now until I get some advice whether that will improve the sound quality of the PM2
Burson 3A Supercharger: This is a rather expensive item and I was questioning the value of its ability to enhance the overall sound quality. What I've read is "maybe" while others stated it provides a cleaner power source that will make a noticeable difference. With what I have read it sounds like it's worth the $225 USD over the stock brick. It appears the worst thing that can happen is I spent the money for little gain, but on the positive side it will make an improvement
I may have questions on a good set of computer speakers which seems to be harder to come by plus I can't really listen to them very loud where I live so those are a bit lower on my list of priorities
I have other questions on cabling, shielding and other aspects on the audio side. I'll post pics on the computer chassis on this thread which I think you will find interesting. It's been a lot of fun fabrication and builing this system. To call it "overkill" would be an understatement but is something I've never regretted. My current rig is still running strong after 12 years.
My main questions right now have to do with whether I swap out the IV side of the Op Amps and just run with what came with the PL2. Once this system is done, I really don't want to rip into it and keep changing things as I want to keep the "tinkering" to a minimum and sit back and enjoy the system once it's finished
Also, if there is anything I may have overlooked let me know. Any advice you can give me would be greatly appreciated
