At the risk of being flamed, I don't see how the composition of the USB cable wire can add warmth to digital data from whatever device is being used as a transport
I understand those concerns to - after all the data is the same. But there are solid scientific reasons why they can make a difference.
In the 1980's, people started talking about mains cables making a difference to the sound quality - and I didn't believe it either - particularly as my pre-amp had 300 dB of PSU rejection in the power supply. But I did a listening test, and yes I could hear a difference. Frankly I still could not believe the evidence of my own ears, so did a blind listening test with my girl friend. She reported exactly the same observation - mains cables did make a difference to SQ.
To cut a long story short, I proved the problem was down to RF noise. RF noise inter-modulates with the wanted audio signal within the analogue electronics, and if the RF noise is random, then the distortion is random too and you get a increase in noise floor with signal. This increase in noise floor is noise floor modulation, and the brain is very sensitive to it; you can perceive tiny amounts of noise floor modulation as a brightening or hardening of the sound. By tiny I mean the noise floor modulation needs to be well below -200 dB, so the brain is very sensitive to it. With the right test equipment, you (APX5555 is only test equipment that has no innate noise floor modulation) can easily measure the effect.
The RF characteristics of the cable can change the RF noise that gets injected into Mojo's ground plane, and this is the mechanism for changes in smoothness. You may say why can't you make it insensitive to it; well I go to silly lengths to RF filter and decouple, and use dual solid ground planes on the PCB, but you can't remove the problem. For Dave, Hugo TT and 2 Qute I have galvanic isolation, and this eliminates the problem (along with other SQ problems such as sound-stage depth). But I can't do this with portable devices, as it draws power from the 'phone. That said it's less of an issue with portable electronics as they are less power hungry and create less noise.
So what are the best USB cables? Firstly, be careful. A lot of audiophile USB cables actually increase RF noise and make it sound brighter, and superficially impressive - but this is just distortion brightening things up. Go for USB cables that have ferrites in the cable is a good idea - it may also solve any RF issues from the mobile that you may have too.
