Dzjudz
- Sep 14, 2005
Since a few days, my Apogee Mini-DAC is exhibiting a very strange issue.
Everytime I turn it on after it's been turned off for a while (it doesn't when I turn it off and turn it on again a few seconds later) it does the following:
All 8 lights flicker simultaneously and fast (not alternating like when there is no input signal but together). When the power switch is on the headphone position (middle) it just flickers. When the power switch is on the 'all' position (right) it also makes an audible ticking noise together with the flickering lights.
This flickering persists for a while (15-20 seconds), then it sort of dies and the DAC returns to normal. A couple of seconds later it starts flickering again for a second and the DAC returns to normal again. After that, the DAC functions normally for as long as it's turned on.
Has anyone else experienced this issue? What do you think causes it?
