Apodizing filter
Feb 17, 2024 at 1:30 AM Post #16 of 426
From what I understand, the Nyquist-Shannon sampling theorem simply states that the sample rate must be at least twice the bandwidth of the desired signal to avoid aliasing. So the 22.05kHz bandwidth limit is merely a function of having the sample rate used for 'CD quality' digital audio set at 44.1kHz. Now if we were talking about 'Hi-Res' digital audio with a 192kHz sample rate, then its Nyquist-defined bandwidth would be from 0Hz-96kHz.
There's also nonlinear distortion introduced with adjustments to lower principle frequencies that can cause aliasing by extending too close to the nyquist frequency, so the recording might be in 48kHz or higher so that is less prevalent during mixing. The main issue on the consumer end is DSP introducing additional distortion pre-amp that causes unintentional aliasing, which is what these anti-imaging filters are supposed to prevent.
Feb 19, 2024 at 11:11 PM Post #18 of 426
ESS Apodizing looks more like Brickwall filter to me. AKM's Apodizing is true to its word: a hybrid of Linear and Minimum phase and in between slow and fast roll-off
Feb 20, 2024 at 7:51 AM Post #20 of 426
Online it says “Its main advantage is that it removes most of the ringing that has been introduced upstream in the recording process when the original material was recorded and mastered.”
But if ringing is only in the ultrasonic range what’s the point of it?
The “point of it” is pretty much the biggest point in audiophile digital audio products these days, marketing! Much of the modern audiophile digital audio marketing employs the strategy of taking some potential problem with digital audio, typically either: Complete BS that never exists, something that was only a theoretical problem but never an issue in reality or something that was an actual problem during the development of digital audio recording in the 1970’s and early 1980’s but was solved shortly thereafter, and then misrepresenting it as a real, current problem. This allows them to market their audiophile product as a solution to this non-problem. Jitter is a classic example, it was an actual issue in the 1970’s but by the time digital audio was released to consumers it was already well below audibility in most consumer devices. By the mid 1990’s jitter was around 1,000 times below audibility in some/many devices and even the very cheapest consumer products typically produced jitter around 200 times below audibility. So a completely solved issue by 30 years or so ago but still commonly misrepresented as an actual problem today in audiophile marketing/reviews.
It’s a similar story with filters. Digital audio was really the first available mass market digital product and in the early 1980’s the processing power of available chips was extremely low (and the software/firmware very rudimentary). So much so, that in some processing areas it was more effective to do it in the analogue domain. Some early pro audio ADCs injected analogue noise to dither for example and Sony’s multi-track digital recorders didn’t have any digital filters, they employed a complex cascade of analogue filters. Of course in the mid/late 1980’s digital audio take up really took off, along with other consumer digital products (video games, office and simple home computers for example) and the development and production of processing chips exploded. The bandwidth and processing demands of oversampling and adequate filtering (which made digital filtering a “no brainer”), became available in the latter part of the 1980’s and during the 1990’s was pretty trivial!
I agree that the super sharp linear phase is the correct filter and the most accurate but 90% of my CD collection is not well recorded it’s compressed rock and metal, in that case I think apodizing or even minimum phase is a better choice for me.
Why would you agree a super sharp linear phase filter is the correct filter, why would you think compressed rock and metal is not well recorded and why would you think an apodizing or minimum phase filter would therefore be better? The only reason I can think is that you’re a victim of audiophile marketing (and/or those repeating it). Referring to the above, what is described as a “problem” or specifically “The problem in practice” is actually NOT a problem. In fact, it’s arguably not even a problem in theory, let alone a problem in practice! Take the posted example of the Dave+MScaler, the attenuation of the freqs above the Nyquist Point (22.05kHz) is roughly -160dB, is that better than a more typical filter which only attenuates to say -115dB? Answer: No, it’s actually exactly the same! In practice of course we are not just measuring the analogue output of the DAC with an AP555, we’re listening to sound, so at the very least we’re constrained by the theoretical limits of sound itself. The absolute theoretical limit of sound is about -23dBSPL, IE. If we had a hypothetically perfect anechoic chamber where no sound could enter from the outside and no sound was produced inside, we would measure -23dBSPL, which is the noise produced by the random collisions of the air molecules inside the chamber. There cannot be sound lower in level than that (unless we remove the air). So let’s say you are listening to your music at a moderately loud but not potentially ear damaging peak level of 85dBSPL, our ultrasonic content at -115dB would therefore be at -30dBSPL, so it cannot exist as sound, in fact it’s roughly half the level required to exist as sound (6-7dB lower than the -23dB level of no sound). The -160dB of the MScaler would be at -75dBSPL, about 52dB lower than required to exist. So, they’re exactly the same, in both cases no ultrasonic sound exists. This is in theory, it assumes hypothetically perfect speakers, amp and anechoic chamber, in practice the situation would be even more silly!
Regarding your other points, most rock is at least decently well recorded, unless it’s very amateur recordings you’re listening to but even then there shouldn’t be much ringing as even cheap prosumer ADCs generally have good filters these days. If it’s heavily compressed during mixing or mastering that will only rarely result in ringing and when it does, it’s of a low magnitude and virtually all in the ultrasonic range anyway (unless it’s deliberate). There’s plenty of other things to be worried about that are audible! The best choice will just be the default filter (the fast linear phase one), there almost certainly won’t be any audible difference between other filter types unless they’re particularly silly, for example, with a roll-off well within the audible spectrum (I‘ve seen some start at around 10kHz), in which case they’ll be worse/lower fidelity.
G
Feb 20, 2024 at 7:53 AM Post #21 of 426
What I struggle to understand is if the who point of the apodizing is to reduce pre and post ringing then why does the ess document actually show more?
An apodizing filter isn't meant to eliminate ringing. As discussed a few posts earlier the only way to remove ringing is either have a properly mastered/produced track with no content above Nyquist anyway. Or use a less effective/slower filter.
An apodizing filter removes much of the ringing produced by the ADCs during recording, and effectively replaces it with its own.
Feb 20, 2024 at 7:54 AM Post #22 of 426
Apodizing doesn't indicate anything particular in regards to phase (or indeed fast/slow rolloff). You can have minimum or linear phase apodizing filters.
Most apodizing filters would be described as 'fast' since you need to fully attenuate before 22khz and so a slower design would rolloff treble more than the same slow filter with a halfband design, but you can still technically have a slow apodizing filter
Feb 20, 2024 at 8:09 AM Post #23 of 426
I’m curious, how do you make an improperly mastered/produced track that does have content above Nyquist?
G
Feb 20, 2024 at 8:11 AM Post #24 of 426
G
Either having an ADC filter that isn't particularly great, or perhaps the most common example in modern music is clipping (though tbh if you've got clipping the resulting ringing is usually the least of concerns :P)
Feb 20, 2024 at 8:36 AM Post #25 of 426
If you had a poor ADC filter, then the ultrasonic content would be aliased back into the audible spectrum and therefore obviously be more audible and something to really be concerned about. Do you have any examples of such poor ADC filters in modern ADCs?
or perhaps the most common example in modern music is clipping (though tbh if you've got clipping the resulting ringing is usually the least of concerns :p)
Exactly, why would you be concerned with low level ringing in the ultrasonic band, when you’ve got a whole spray of overload distortion products in the audible band. It’s like trying to fix a scratch on the back of your car that you can only see with a magnifying glass, while ignoring that the front of your car has been obliterated by a tank! There are potentially some creative uses for clipping but ultrasonic content is irrelevant, there will always be some significant amount of error signal (above Nyquist), with or without clipping, that’s why an anti-image filter is required in a DAC.
G
Feb 20, 2024 at 8:37 AM Post #26 of 426
I'm not necessarily saying I think apodizing filters are the ideal approach. Personally I prefer non-apodizing in most circumstances
Feb 20, 2024 at 9:05 AM Post #27 of 426
Sure but I’m trying to ascertain why “a properly mastered/produced track with no content above Nyquist” is a way to remove ringing or conversely, how an improperly mastered/produced track has content above Nyquist and which does cause ringing?
G
Feb 20, 2024 at 12:27 PM Post #28 of 426
G
On paper I’d say that linear phase is the most correct because of no phase shift. Minimum phase has that problem but it’s likely to be much lower in amplitude compared to the initial attack. For listening I’d say minimum phase with no pre ring is preferable for me.
When I compared chord mojo 1 (linear) and apple dongle (minimum) preferred the dongle for sounding more spacious and natural compared to the thicker and sharper sounding chord. The difference is small to me but one I still prefer.
Feb 20, 2024 at 6:15 PM Post #29 of 426
Which is not transparent, the Chord Mojo or the Apple Dongle? I've heard of controlled tests of both of those saying they're both audibly transparent. Did you compare them level matched and blind?
Feb 20, 2024 at 7:14 PM Post #30 of 426
Yes I did, anyway even if expectation bias or placebo played a big part in this then wouldn't it be for the far more expensive chord mojo over the £9 apple dongle?
To me the dongle sounds more pleasant, they both measure well so im putting it down to the minimum phase apple uses.
I've been listening to my favourite albums for over 30 years, still the original CD pressings. I can easily tell when something has changed for the better or worse.
