Nnnno, I don't see any reason to assume that.
Nothing is being assumed, except in your case of incorrectly assuming what you think the “
foot” of “apodizing” means. We’ve merely explained the basics of what “apodizing” means in the context of digital audio filters.
Dithering is intentional statistical manipulation to remove some of the effects of "natural randomness" that we don't like to see …
Dithering is entirely another subject, not related to digital filters, so you’ve gone off on a bit of a tangent here and unfortunately got that wrong too! Completely contrary to your assertion, dithering is not a “
manipulation to remove some effects of natural randomness” it’s the opposite, a process that actually adds randomisation to the data/signal.
It's more likely that it isn't dithered and that's why it produces so many unintuitive results and throws us off with "cloud bunnies" etc.
I’m not sure exactly what you’re trying to say here but the likelihood that some digital audio signal/data is not dithered, is precisely zero! It is an inherent part of the digitisation process and every professional ADC ever made dithers the signal. Therefore your “
and that’s why” you get unintuitive results and whatever “
cloud bunnies” are is entirely false/non-existent.
what i found (and many seem to think that way) go with a slow roll off filter (i mainly used the linear phase slow roll off and minimum phase slow rolloff)
What “
many seem to think”, a relatively few delusional audiophiles? The professionals; audio engineers, digital audio filter designers, the various manufacturers of professional ADCs and DACs all unanimously think that a standard fast, linear phase filter is the “way to go”. In fact there’s no choice, all professional ADCs only implement that standard filter type, there are no filter choices. It’s only in the audiophile world where that unnecessary (marketing) choice exists.
now the thing is... you want the gentleness of the slow roll off filter (because of the sound quality) but without its cons (potential nyqist/antialising artifacts)
What do you mean you want a slow roll off filter “
because of the sound quality”, why would you want lower sound quality and why would you recommend that to others? A slow roll off filter “
without it’s cons” (the loss of audible freqs or potential anti aliasing/imaging artefacts) is called a fast roll off, linear phase filter, which is why professional ADCs only implement fast roll off, linear phase filters!
what you can do is this: upsample 44,1khz to 192khz on your player, and let your dac run at 192khz with material that will never reach the nyqist frequency....
3 benefits:
1. if you use good upsampling and your dac "likes" the samplerate upsampling will improve sound quality
2. the gentle slow roll filter will improve sound quality, without potential artifacts
3. when upsampling to the highest samplerate your dac supports you sometimes circumvent resampling on the chip itself depending on the dac chip, thats why upsampling can sound so good imo
1. No it won’t, unless something is seriously broken it will have no effect on SQ at all.
2. No, it will do the exact opposite! How does reducing potentially audible treble freqs in the recording somehow improve SQ, how does this deliberate reduction in fidelity “
improve sound quality”?
3. Why do you want to upsample, in order to avoid upsampling? How does that make any sense? What imagined deficiency do you think a DAC chip has, that’s specifically designed to upsample and that DAC chips have been achieving perfectly (beyond the limits of audibility) for over 30 years?
As all three of your “
3 benefits” are actually not beneficial then your assertion to upsample on your player is false!
G
