tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
I come down between these two rework points of view. Yes, blindly reheating all the joints can cause more problems than it solves, because you can actually make more cold joints this way. If you have some liquid flux, adding a bit of flux to each joint before you reheat it will remove this risk. Even so, this is the hardware version of shotgun debugging -- like waving a shotgun around and pulling the trigger at random, hoping to 'shoot the trouble' if you pull the trigger enough times.
I'm also not a fan of completely desoldering and resoldering everything just to find one bad joint. You can almost always find a cold joint just by looking at it, but this requires experience. If you don't yet have that experience, the reheating method is probably best. To get the experience to be able to identify cold joints, retest the amp between joint reheats so you can remember what the joint looked like before you reheated it. Eventually you will be able to identify cold joints just by looking at them, which means you won't leave cold joints for the testing phase to begin with -- you'll see them right after you make them, and fix them immediately.
Getting back to the problem at hand: finleyville, now that you have a working amp, remove your temporary modifications one by one, getting back to the way you had it before, testing each step of the way. I would first put C1 back in, then replace the pot, and finally swap out your small 'lytics with the big ELNAs you want to use. If bad assembly technique was your only problem, then you can just resolder all of the parts to the board and it will work this time, but you don't know that yet. You need to re-test at each step so that you know what really went wrong. You may have bad parts, or a cracked trace or something else entirely.
On your RCA jacks, are you using a metal case? If so, your chassis grounding might be incorrect.
