JimBob1971
- Mar 17, 2007
Hi,
I've been using either my TF10 pros or E500s with my iPhone.
Recently the left channel went on the Shures, so I sent them back and Shure replaced them (Thanks Kelli!).
Anyway, the replacement set died today - this time the right ear-. now, I wondering whether there is some problem between the two , or whether I've been doing something daft! They don't die mid play. It is when I first put them on. I've checked the cables, and there is nothing doing there.
Potential causes:-
1) I was using the UE attenuator with the Shures and I noticed that the right channel would intermittently drop out. As soon as I removed the attenuator the channel came back fine. So I thought the attenuator was dodgy. However, the same channel is permanently down now, with or without it.
2) I shower every morning, and wear my phones about 10 mins after. Having said that, I've done the same with two different UE sets, as well as Shure E4s with no ill effect
3) Maybe there is a problem with my iPhone (although no other headsets are affected). Would the Shure iPhone adapter help?
Anyone else had this, or able to suggest causes/solutions? Thankfully Shure are going to replace them again, but I don't want this to happen again.
Cheers!
Potential causes:-
Cheers!
