tomhirvin
- Jul 5, 2004
I have finally decided to sort my trusty E4cs out which have worked perfectly for nearly 15 years without complaint.
Unfortunately and not surprisingly the cables are now coming away from the head units which is causing the sound to cut out intermittently.
Can anyone recommend someone or somewhere in the UK who could repair these? Or maybe recommend a fix. I might even consider a moulded earpiece.
I have finally realised that I do more harm than good with my soldiering iron so will not be attempting any fixes myself involving solder,
