Anything should do as long as the build quality isn't garbage. USB is a digital cable so it's all or nothing, so there shouldn't be any real variance between cables unless one is straight up defective. I guess if it's being used to power a device that might be a concern, but I think that's more of a PC power supply issue.
Assuming you mean USB 2.0 type B
Amazon has some
https://www.amazon.com/Cable-Matters-USB-C-Printer-Scanner/dp/B00VKSF39O/ref=sr_1_3?s=pc&ie=UTF8&qid=1478759075&sr=1-3&keywords=usb+b+to+C
Monoprice has some
http://www.monoprice.com/product?p_id=14830
And newegg if you're feeling rich
http://www.newegg.com/Product/Product.aspx?Item=N82E16812288051&ignorebbr=1
I think you'll just have to get lucky with a unit that was built well so the physical plugs don't wear. But if you feel the need you can get clamp on ferrite beads for extra protection against interference.
