jiiteepee
- Apr 5, 2005
Hmm... do you happen to have some USB device connected there with most software installed there ... as like a USB Printer etc.. It's possible that the system scans the state of this device or it's connection port regulary and this procedure brings audible issues (sometimes even a normal printer through parallel port gives some issues when set wrong). I've noticed this type issues with HP PhotoSmart USB device in conjuction with WinXP.
If you do have one there then, just try by disabling the device through Device manager and remove all it's realtime functionality (those loaded programs are propably showing up as icons in most right area in taskbar). You can try by killing those processes temporarily through TaskManager first and then if this helped then just remove/prevent from running permanently (for this task you can use an utility called autoruns (you'll get it from microsoft support)).
Sometimes adjusting the graphics acceleration and mouse sampling rate helps a bit too (but propably it's not your case).
jiitee
jiitee
