any experiences with USB DAC's (on linux)?
Dec 5, 2008 at 5:30 AM Post #17 of 25
Originally Posted by skamp /img/forum/go_quote.gif
How many times does it need to be said: USB 1.1 is NOT limited to 48kHz.
Thanks for correcting. Which USB 1.1 DACs go up to 96kHz? Know any USB DAC that can go 96kHz using the usbaudio driver?
Dec 7, 2008 at 1:06 PM Post #19 of 25
As far as I know, the standard streaming audio is only up to 48kHz, and that should work with pretty much anything. Anything higher is a device specific and needs special driver support (I don't know if they are just extensions to the standard streaming or completely different packet format.)
I have also Edirol UA-25 and it works at 96kHz, but in that mode it does not look as a normal usbaudio device to lsusb command.
Dec 13, 2008 at 6:49 PM Post #20 of 25
Hi
I use a Trends UD-10.1 under Ubuntu Ubuntu 8.10 "Intrepid Ibex" (also get Rates: 32000, 44100, 48000 as nyc_paramedic already posted)
Had some trouble first getting any output to the Trends (connected to my Yamaha receiver via coax). I just managed it changing the gstreamer settings (in console: gconf-editor) and I created a .asoundrc file for ALSA in my home folder
"aplay -l" gives me this output:
card 0: Intel [HDA Intel], device 0: AD198x Analog [AD198x Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: HDMI [HDA ATI HDMI], device 3: ATI HDMI [ATI HDMI]
Subdevices: 1/1
card 2: default [USB Audio DAC ], device 0: USB Audio [USB Audio]
Subdevices: 0/1
my .asoundrc file looks like this:
pcm.!default {
type hw
card "default"
ctl.!default {
type hw
card "default"
I use mpd (Music Player Daemon: Music Player Daemon Community Wiki) with this config file (mpd.conf):
audio_output {
type "alsa"
name "default"
device "plughw:2,0" #have to change this entry sometimes because the device has not always the same "number" (depends on when it's loaded by Kernel?)
My question now is wheter I have to change/add something in one of those config files or somewhere else to get bit-perfect output. I also don't want anything in my system to alter the signal - just the most direct connection to my Trends UD-10.1.
Here I found a little info on bit-perfect output ( ALSA select digital audio out (bit-perfect)) - but I'm not sure how to correct it for my system:
audio_output {
type "alsa"
name "SPDIF"
device "cards.pcm.iec958"
I'm actually a linux-newbie so please be patient (it's a miracle I even managed to get any output at all
Any input of more experienced linux-users would be much appreciated! (Other comments as well of course)
Thanks!
Dec 18, 2008 at 10:07 AM Post #21 of 25
Hotaudios work well too on Linux
Dec 18, 2008 at 3:24 PM Post #22 of 25
Corda 3move works well
gav7 ~ # cat /proc/asound/card1/stream0 | grep Rates
gav7 ~ # aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: PCM2702 [Burr-Brown Japan PCM2702], device 0: USB Audio [USB Audio]
Subdevices: 0/1
gav7 ~ # uname -a
Linux gav7 2.6.23-sabayon-r1 #1 SMP Fri Nov 23 05:27:12 MSK 2007 i686 Intel(R) Celeron(R) M processor 900MHz GenuineIntel GNU/Linux
Dec 20, 2008 at 1:48 PM Post #23 of 25
Style Audio Carat Peridot here - works fine
Code:
Code:
[left]aplay -l **** List of PLAYBACK Hardware Devices **** card 0: default [USB Audio DAC ], device 0: USB Audio [USB Audio] Subdevices: 1/1 Subdevice #0: subdevice #0 cat /proc/asound/card0/stream* | grep Rates Rates: 32000, 44100, 48000 Rates: 32000, 44100, 48000[/left]
It's running through a powered hub so no lsusb available (need more USB ports!)
Dec 23, 2008 at 2:16 AM Post #25 of 25
My first experience w/ USB audio on Linux was with an old version of Debian. I had severe aliasing issues in the upper frequencies that made it practically unlistenable.
Newer Linux distros (I've also tried it on Ubuntu 8.04) work great without the aforementioned issues.
