Borky
- Jun 8, 2004
The volume level on my system keeps fluctuating, at one point -20db on my receiver is pretty loud then -20db is soft and not loud enough so I have to turn it to about -5db or so. Also, In the Via Audio Deck, I can't control the volume with the Master Volume Slider. Simply nothing happens when I put it up or down. I'm running the 1.43d drivers, should I consider getting the new ones?
If so, would it be the PTs, HTs, or which?
