DDF
- Aug 11, 2006
After much searching and experimenting, it appears there is no way to stream music files in Kit Kat over a DLNA/Twonky home network, and then out to an external USB audio dac.
Experimenting with a Samsung Note 10.1 2014 edition, USB Audio Player Pro works perfectly to my external DAC, however, it won't connect with a WD Live (twonky/dlna) home server. SlickUPnP, BubleUPnP, WD My Cloud and other apps have no problems seeing the server and playing every file format I throw at it.
Is this a limitation of USB Audio Player Pro?
I tried Slick UPnP which then selects a player, but unfortunately it doesn't list USB Audio Player as an option when going to play a networked file, so the integration doesn't work.
Is there no way to play a music file from a Twonky/dlna (eg WD Live) based home network to USB Audio Player?
Thanks for reading this!
Dave
Dave
