Garbz
- May 19, 2004
A friend donated a "dead" 2x250watt poweramp to me the other day to "fix". I use the inverted commas simply because I undid the changes he made that caused the breakage in the first place. He really couldn't be bothered fixing it and just went out to buy a proper one.
Anyway I replace the components that were (under the false idea that it would fix a ground loop) removed, and it is working as intended except for a slight hum which I may consider debugging at some stage.
http://www.garbz.com/shem1.jpg this is the schematic for the amplifier. The part removed was R31 (10ohm 5W resistor from -ve input of the Q3/4 longtailed pair to ground).
Bear with me but since I am trying to teachmyself the transistor theory I really want to know exactly what removing R31 did to cause the 50V of DC that torched the poor guy's speakers, that is in terms of how it affected the current through Q3/Q4.
