rhz
- Nov 6, 2006
Hi, Everyone.
I am looking for a new pair of headphones to use in an office. I very much enjoy the neutrality and comfort of my Grado SR-60 open headphones, but the noise leakage would be problematic at work.
I am looking for a new pair of headphones that (mostly) satisfy the following criteria:
Source Compatibility: I have a FiiO E10K USB DAC and Headphone Amplifier which I use with the Grados. At work I have a Macbook pro which I have used to directly drive the Grado headphones and found the sound acceptable (albeit perhaps slightly more shrill than with the fiio headphone amp). I'd like the new headphones to give good performance with either source. I listen to rock, jazz, blues, country, and sometimes classical.
Comfort: I can wear my Grado headphones for hours without feeling like I have something heavy on my head and without developing red-ears from an overly tight grip.
Sound: While different people may perceive "neutrality" differently, I enjoy the balanced, even sound of the Grado headphones. A little deeper bass would be welcome, but only if it is, natural, well-defined and not exaggerated in any way.
Portability: I would probably want the ability to carry these home with me, possibly on a daily basis. If they fold up to something compact and have a decent protective case, that would be great.
Durability: I may be transporting these in a backpack to work and back, so they should be fairly sturdy. A detachable cord is a plus.
Noise Leakage: This is very important. I have a quiet office environment and, while I don't blast music, I do sometimes listen at a fairly loud volume.
Cost: Given the sources I'm using, I'm not sure what benefit a very high-end pair of headphones would provide. I am willing to spend about $75- $150.
My initial research identified the Audio Technica ATH-M40(x) or M50(x) as candidates. Can anyone comment on those headphones in light of my desires and/or add to the list?
Thank you very much!
I appreciate everyone's help.
RhZ.
RhZ.
