General rules of thumb:
The main reason I braid my solid silver cables is to enhance the strength. Solid silver has the least capacitance anyway. |
Solid silver or any other conductor has no capacitance in and of itself. As was posted here earlier, capacitance is determined by the effective distance between and total surface area of two conductors in proximity to one another.
...My understanding is that twisting is valid and neccesary for differential circuits to perform correctly, but is pointless or even detrimental for unbalanced, non-differential circuits. |
All other things being equal, a twisted pair will have higher capacitance per foot than two non-twisted conductors. This is because they'll be in closer proximity to one another. However as a twisted pair, they'll also reject RFI much better because with each twist you invert the phase of any induced signal which then self-cancels as a result.
A low impedance circuit will be less affected by capacitance than a high impedance circuit. So typically, line level "inputs" which normally have a characteristic impedance of 10k ohms can be affected by capacitive loading from cables.
Obviously the typical input will be very sensitive to RFI so normally, mic and line level interconnects should be shielded unless you live in a Faraday cage.
Typically, speaker level outputs being very low impedance will not be affected by nominal cable capacitance. Since most of us live in an industrial/urban environment, even speaker cabling should be shielded (i.e. twisted) in some way if there is any length involved because RFI can get back in to the amp through that route. Some amps are sensitive to this, some are not. Typically depends upon things like the degree of negative feedback unsed in the design, whether or not loading coils are used in the output, which tend to act like RF choaks, etc. My .02...
Cheers
