Rhinomyte76
That's exactly what I was asking. Thank you!!
I would be interested to know as well. So is your amp going to take 9 pin native or the 8 pin?The input is a 5751/6SL7. Do I have to be wary of low gain variants (12AU7 w adapter / 6SN7) properly driving 2x 300bs? Does the fact that I will be using ZMF's (ie, a little harder to drive) make a difference?
9 pin native. That's really good to know re: 6SN7. I definitely want to avoid paying for an expensive NOS tube and not being able to use it. May be worth emailing Justin on your issue. He's always been very responsive. I just hate to bother him if there's another Head-fier who can educate me.Sorry misunderstood your last post as I wasn't focusing on this part:
I have BB Rev2 so it takes 9 pin. I tried using an adapter with some of my 6SN7, but the heaters didn't power up. I think the adapter just isn't compatible with the way the heaters are wired in the BB, but not sure. I wonder if anyone is using an Octal adapter with the BB Rev2 that works?
I actually intended to send him an email, but got sidetracked trying all of the 9 pin tube options. I'm glad your post reminded me of it, though.9 pin native. That's really good to know re: 6SN7. I definitely want to avoid paying for an expensive NOS tube and not being able to use it. May be worth emailing Justin on your issue. He's always been very responsive. I just hate to bother him if there's another Head-fier who can educate me.
Great. Thank you.ECC99 for the driver of a 300b is likely what you meant.
EC99s are pretty amazing tubes... yet it would work for a Agartha, but Id lean toward the 12AT7 or 12AX7... most (all) single ended amps, esp with a single gain stage sound better with more drive. Before getting exotic tubes you might be SHOCKED what a basic preamp can do to add to sonic bliss.
The only reason is that I have some really good 6SN7 around that I like the sound of. I thought I would give them a shot. It was an inexpensive adapter that I had from Ali. I checked that each pin had continuity to another, but did not verify pinout. Maybe I got lucky that it didn't damage anything if it is defective or wired wrong. I don't feel compelled to try it again at this point. LOL. At least not without a quality adapter. I've found several great options in 9pin anyway. Thanks!Hey everyone... hopefully most know Im a phone guy more than emails... I write a ton but dyslexia and public review of my replies encourages me to make responses really shot.
There should be no reason a 6SN7 didn't light up... nothing fancy or different in how we do it... the filaments can handle it... maybe a bad adapter.
That said... but why? There are sooooooooooooooooooooooo many alternate choice that would be better. For many who have an octal front end, moving with adpater to the 9pins (12AU7-12AX7) brings more drive and a reduced noise floor. If your amp can handle 9pins natively, youd be wisest to stay within that family and find 9pins that bring you joy rather than 8pins... but thats just me. With the right (correctly func) adapter you can do it.
I’m the same, but with a Rev 1 bigger Ben I’m going from 6sn7 to some good 12au7/12at7. I’ve been getting my adapters via eBay from xulingmrs and been overall pretty pleased. I think one issue ever.The only reason is that I have some really good 6SN7 around that I like the sound of. I thought I would give them a shot. It was an inexpensive adapter that I had from Ali. I checked that each pin had continuity to another, but did not verify pinout. Maybe I got lucky that it didn't damage anything if it is defective or wired wrong. I don't feel compelled to try it again at this point. LOL. At least not without a quality adapter. I've found several great options in 9pin anyway. Thanks!
Xulingmrs makes some good adapters and they are worth buying from her in China.I’m the same, but with a Rev 1 bigger Ben I’m going from 6sn7 to some good 12au7/12at7. I’ve been getting my adapters via eBay from xulingmrs and been overall pretty pleased. I think one issue ever.
ThankyouI have a Bigger Ben and it sounds great paired with the LCD-5 as well as the Sol. P and Sus.
Plenty of power with KT-88 even for the Sus.
