Justin will a 12AU7 work as well with a Kenzie? I already have an adaptor and I could use more range on the volume pot I max out at 9 AM. If so do you have a recommended 12AU7 you like for the Kenzie, I will give it a try. I have lately been using an RCA grey glass 12SL7GT but am always looking forward to trying new tubes. I was lucky to find a stash of Tung Sol 1626s that should last me for a few years.Most dynamic headphones are very very sensitive relative to other designs.
When paired with powerful tube amps with will provide amazing slam, while still providing the body and tonal richness which is the hallmark of these amps.
The Pendant is compatible with many different 12AX*7 variety tubes. Changing to a 12AU7 will reduce the noise floor and increase the practical movement of the volume pot.
Whats great, is that changing this one tube will allow for better system matching/reduce noise floor as needed with varying sensitivity headphones.
