with my limited headfi experience (less than a month), I would agree Heahphone Amp may not make big enough difference to justify the price.
When i first checked in Head-fi.com, I wan looking for my first headphones since night listening disturbs my young kids. I wanted to to straight high level and then decide what to afterwards.
For headphones, thanks for all the info from this forum, I ordered the following to the following:
--AKG K701
--ATH-AD2000
--Shure E500 PTH
--Etymotic ER-4S
but I couldn't get any decisive info on Amps. I will only want an Amp for my office at work, where I will be using computer/iTune --> digital out. So I want decent DAC/Amp combo. From the header list of this site, I get into Headroom.com and seems they are quite reputable and high quality vendor. So I ordered pretty much their top-of-the-line gear:
Desktop Amp + MAX Amp module + MAX DAC + Stepped Antenuator + Separate Desktop Power Supply = $2016.
Since I want smaller footprint and only one phone output, I didn't feel like the MAX Amp model. According to HeadRoom, the combo I got performs almost exactly the same as MAX Amp.
Ok, got all the shippment the last two weeks. I started quite intensive A/Bing.
--First thing out is the Ety ER-4S, no bass and too lean. returned back to Amazon.
-- Shure E500: awesome! good is almost everyway, sound, comfort, low profile. a keeper.
--Audio-Technica AD2000: awesome! great overall except quite uncomfortable to my ears! the sound is so much like my speakers. The bass is much better than K701. Sounds fuller as well. Sounds flawless.
-- K701. GREAT! so neutral and clear. I literally hear each individual instruments without fatigue. Soundstage is wonderfully wide and well postiioned. But I don't want keep too many headphones around so decided to let this one, but I'm a little regretted already!
Ok, the HR DAC/Amp. I was expecting
quite dramatic improvement over the company issued desktop computre soundcard output. I used Apple Lossless format and iTune, then USB digital output to the Amp. To my shock, I honestly couldn't hear much of a difference. I kept changing genre to test base, treble, stage, image, female vocal, male vocal, fast, slow, ..... Is there a difference, yes only sometimes yet they
very subtle indeed. There is one track that computer soundcard has static noises, while HR smoothed it out quite nicely, so I know the HR DAC does a better job here. But does it worth > $2000 ? not in my judgement. I don't mind the price at all, in fact I was planning to spend more, but I'd like to get matching return from it. So the whole thing stopped me from moving on the Amp ladder.
FYI, here is the excerpt from Heedroom about the DAC/Amp:
Digital to Analog Converter (DAC) Options
Now, on to the various available Desktop Amp DAC options. The basic 'Desktop' DAC is based on the Cirrus CS4398 chip which is their top-of-the-line, flagship DAC. There is actually not too much we can do here to make it sound even better but, as always, we give it a darn good shot!...
The other thing that can be done for ultra hot-rodded DAC performance is to insert an asynchronous sample rate converter and do a bit of fancy up-sampling and complex de-jittering. Well, that’s precisely what we've done in the 'Max' DAC. A lovely AD1896 chip lives between the digital receiver and the DAC. It takes the incoming digital data, stores it, up-samples it, interpolates it, picks a nice juicy word, and then clocks it out right on time. The thing probably does more complex math in half a millisecond than you’ve done with a calculator in your entire life!
Electronics Module Options
The 'electronics module' is the internal circuit board chiefly responsible for the amp's sound quality. Because it will cost significantly more to swap or change later on, the first option you should consider is which freshly-revised HeadRoom electronics module to have installed within the Desktop Amp. The Desktop Amp comes stock with the very punchy, articulate and authoritative 'Desktop module'. This is a superb-sounding, crisply-detailed and exquisitely well-balanced module choice and will deliver more than enough robust audio performance for most discriminating listeners.
The top-of-the-line 'Max' electronics module is physically quite a bit larger to accommodate the one-to-a-package Burr-Brown OPA627 op-amps. These parts are some of the most expensive audio op-amps money can buy, and they are totally worth it. Liquid-quick, transparent, intricately detailed highs and a deeply textural, rich bass response bracket an organically ultra-smooth & silky midrange. We are head-deep into serious Class-A operation here, folks! In the 'Max' module, absolutely NO expense is spared right down to the gold coated, double-thick 2 oz. copper-traced, four-layer circuit board... Woo-Hoo! Long live the HeadRoom module king!
I tend to agree with some fellow posters there that headphones count more than 90% of the sound quality, given reasonable price consideration.
