Amps and sensitive headphones issue.
May 22, 2015 at 7:36 AM Thread Starter Post #1 of 7
Draulius
Hello, I'm new to Head-Fi and have an issue concerning AMP DACs when paired with sensitive headphones. Currently, I use the Schiit Fulla AMP DAC with Audio-Technica AD700 headphones. It sounds a bit better than the on-board audio, but there's one problem; I can't use 90% of the volume knob because of how sensitive these headphones are (only 32 Ohms). If I turn the volume up more than 10% of the way it will be way too loud. This makes fine tuning quite difficult, especially when I need to do it on the fly. It doesn't help that the knob on the Fulla isn't very good either.
Could I live with this problem? Sure. But there are a couple of ways I could deal with it too. The first option is I could replace the AMP DAC with one that has lower gain. I don't know of any good ones for that so this is where recommendations come in. The second option is that I could switch to headphones that require more power ($200 budget), but I don't like this option since I really like these headphones. They're suitable for my purposes which include gaming and music, so the soundstage comes in handy.
I am also open to any other suggestions.
Thanks!
May 22, 2015 at 8:25 AM Post #2 of 7
H20Fidelity
Have you considered something like this simple cable?
http://www.ebay.com.au/itm/3-5mm-M-F-1M-Stereo-Headphone-Audio-Extension-Cord-Cable-with-Volume-Control-New-/251258582811?pt=LH_DefaultDomain_15&hash=item3a802db71b
It would you allow to adjust the max volume on the Fulla and headphone volume from the provided cable.
May 22, 2015 at 8:25 AM Post #3 of 7
SteveHiFi
Member of the Trade: HiFi Headphones
I imagine you can find an attenuator which you can plug your headphones into and which will go in your amp's headphone socket.
Also the 'Shure EAADPT-KIT Adapter Kit' includes a similar thing with its own volume control to add a bit of resistance and give you a bit of extra control.
May 22, 2015 at 8:36 AM Post #4 of 7
Draulius
Personally, the last thing I'd want to do is add another volume controller. I don't like having to mess with them much in the first place, so I probably wouldn't be comfortable with that setup. If I really wanted, I could lower the Windows volume to give me more room on the AMP DAC.
Regardless, thanks for the advice.
May 22, 2015 at 9:17 AM Post #5 of 7
H20Fidelity
No problem. I think what you want deep down is to spend more money on another dac/amp or headphone.
For that purpose you're in the right place.
If its a dac/amp you want maybe consider the iBasso Dzero MK2.
Goodluck friend.
May 22, 2015 at 10:51 AM Post #6 of 7
ProtegeManiac
Manila
Just to clarify, "32ohms" is the impedance; its sensitivity is 98db/1mW.
You can also lower the source volume for free (reduce Windows/OSX volume setting to 75%).
May 22, 2015 at 12:21 PM Post #7 of 7
FlyingGimp
As Protege says, you've got a free option to fix this in changing the source volume.  Just make sure to set your dac to 24-bit/44.1kHz mode so you don't lose any information.
Here's the dialog on Windows:
http://superuser.com/questions/698522/how-should-i-decide-on-a-default-audio-format
And a thread with details on 24-bit vs. 16-bit:
http://www.head-fi.org/t/671220/effective-number-of-bits-or-why-you-have-to-keep-software-at-full-volume-is-nonsense
