starblue
- Jul 18, 2013
Hi all,
I am not sure if this is the right sub forum for my question so mods please feel free to move if necessary.
My question is around harnessing the benefits of balanced circuit in amps if the headphone is unbalanced/has normal stereo jack.
My gear
Amps/players with balanced output
- audio GD NFB 27, has balanced four pin XLR output socket
- Pioneer XPA 700 with pioneer's 4 pin balanced output
- Sony HA 3 with 2 separate single channel balanced outputs
- Onkyo DP-X1 with a single mini 4 pin balanced out
Amps/played without unbalanced output
- Pioneer N70 A
- Woo Audio WA6SE
- Ak120
Headphones
- Audeze LCD 3 4 pin XLR balanced cable
- Fostex TH900
- Denon AH D5000
- Senn HD 800
- Shute open back flagship (can't remember the model name right now)
- Sony mid tier headphone, again can't remember the name
All except LCD3 have stock cable with standard 3.5 or 6.3 mm stereo jack. Which means although most of my amps are balanced, I can't use balanced inputs
I also don't want to loose the flexibility of using standard stereo output in case I buy some new amp or player without it.
So what are my options
- is it possible to custom build adapters - male in to amps balanced output with female socket for standard male stereo at the other end. In other words, amps balanced to unbalanced headphone. Advantage - headphones are untouched, can be used as such with any standard player, potentially cheaper than reterminating or rewiring.
- is it possible to custom build opposite adaptor -I.e reterminate all headphones to balanced, let's say 4 pin type XLR and have (I) balanced adapters depending on the amp output socket type which should be Ok I believe and (II) have balanced 4 pin XLR to standard 3.5 or 6.3mm stereo adaptor, if it's possible, so that headphones can be used with standard players as well if required.
So my question is
- which one of the above are possible without destroying my amp (shorting output circuit)
- what else do I need to be careful about if I go either of the above route ?
Thank you for your advice on advance!
Sent from my iPhone using Tapatalk
My gear
- Pioneer N70 A
- Woo Audio WA6SE
- Ak120
Headphones
- Fostex TH900
- Denon AH D5000
- Senn HD 800
So my question is
