luizffgarcia
Yep not sure either, it is tricky when it comes to headphones and specially IEMs. For IEMs without a proper seal you get like zero bass.Not sure if those stats base the amount on what comes out of the headphone, or what gets in the ear. Because Sean Olive often mentions how a lot of the preference variations for bass can be explained by placement and quality of seal. Where basically, some people want more bass because they're not getting as much as the other guy from of a poorer seal based on how they wear the headphone/IEM.
I doubt that would turn out to be why you want +15dB, though.
But yeah not my case because i also add a few dBs when using speakers as well, hahaha
