Bazza Hallward
- Nov 7, 2016
[color=rgba(0, 0, 0, 0.870588)]The OPPO doesn't specify its output impedance but I believe that it uses a Texas Instruments headphone stage. Texas Instruments recommended an output impedance between 10 and 100 ohms for their headphone stage, but I guess it depends on the application. [/color][color=rgba(0, 0, 0, 0.870588)][/color]
[color=rgba(0, 0, 0, 0.870588235294118)]The NAD C165bee has a discreet headphone stage. And its 10 ohm output impedance is better than most stereo amps and pre-amps and in fact better than some dedicated headphone amps. The sound is definitely richer via the NAD over the OPPO, but isn't necessarily more controlled.[/color][color=rgba(0, 0, 0, 0.870588)][/color]
[color=rgba(0, 0, 0, 0.870588)]I did also try a Quad PAOne tube headphone amp. It has a 32 ohm output. That didn't work so well with the Grados. But again, it may not have been an impedance issue, but just not the best match. With the Quad, the sound was too warm in the bass and hot in the midrange. It may have even lacked control at higher volumes because the sound became looser with more volume.[/color]
[color=rgba(0, 0, 0, 0.870588235294118)]When I owned the HD 600s I ran them out the headphone out of a Cambridge Audio 840A. I concluded that the HD600s needed a dedicated amp... it wasn't a volume issue, it was a lack of dynamics. But again, it may have been a poor match with the Cambridge Audio amp and CD player, which were both on the more staid side. The HD600s with the Quad... now that would be interesting to try.[/color]
[color=rgba(0, 0, 0, 0.870588235294118)]You're right in saying that I won't know if I am getting the Grado sound (or the sound I am after) until I hear them on a few well-matched headphone amps. It might be worth trying to trial some amps in a shop.[/color]
