Amp for Fiio E10K DAC ++ "Immersive" headphones
Feb 18, 2015 at 2:23 PM Post #16 of 19
Is that an issue with the DT990's then, or the E10K? Would you recommend any other headphones around this price range to pair with the E10K?
I read that DT990 is more bright than DT880 so, for me, is a problem. Prehaps for you it ain't.
I'm currently using with a DT770/32 and a X2/30(or so) and they both sound great on E10K. The soundstage is a little narrow and the mids are kind of recess. Overall sound for a 75$ equip is amazing.
Feb 18, 2015 at 2:51 PM Post #17 of 19
E10K is a very linear (neutral) device and has enough power to drive DT990 250 Ohm.
DT990s are bright headphones, if you listen to high quality recordings, this shouldn't be a problem.
On the other hand, if you normally listen to low quality recordings, most modern mainstream music/highly compressed recordings with typical flaws like strong sibilance, then DT990s are not the safe way to go.
Best Luck!
Mar 9, 2015 at 1:40 PM Post #18 of 19
hope this isn't too much of a necro post.
I have an e10k and like it and use it at work. I'm very happy with the improvement over my laptop's output
I'm able to get a good deal on a pair of almost mint condition HD800s from a friend of a friend - I'd be paying less than I could sell it for. More than I want to spend but I do presently have the wherewithal.
How does the e10k work with the HD600s? Do you think it'd work alright with the HD800s which are supposed to have similar characteristics?
I don't want to spend a TON of cash on a dedicated amp, with any luck I'll be starting grad school in a few months and that'll be eating up my income(I'd be paying as I go straight from my paycheck at an expensive, well known private university and hopefully graduating with minimal, if any debt).
Mar 9, 2015 at 2:09 PM Post #19 of 19
Hmmm in power terms e10k should be enough to hd600. Not by much though. The question is: Will it sound good? I don't think so
