deadlierchair
- May 4, 2003
My question specifically pertains to the CMoy but could apply to any portable amp I guess. The question is, how low should measured voltage get before you stop using that battery in your amp? I've been using a 9 volt battery in my CMoy for about 2 months and now it's reading at about 7.9 volts.
At what level should I stop? Does quality degrade over time? Is there are good set level to stop at, or should I use it until it won't amplify anymore?
